1000HX how much more can it take?
1034 25
am i starting to push my sig rig to hard or is it fine?
Reactions: Oupavoc
1 - 20 of 26 Posts
Needs more Hard drives sir
OG OC
You're fine, shouldn't be too much for that beast. Just make sure you spread out the load over the two rails.
Don't worry at all. You aren't stressing that PSU.
Originally Posted by RAFFY View Post
your power supply isnt even breaking a sweat! your good to go, get a 295 for physic x
This.
Would be one hell of a PhysX card.
Guys, have you seen his avatar?
Your best bet for a physx card is a single slot 8800gt/9800gt/gts 250
Reactions: tpavur
ya but a gtx295 is future proof
, lol
Originally Posted by Chranny View Post
This.
o it would!!!
I'd say your PSU can handle quite a bit. When I first was running my TRI-SLI I use'd my 750TX for about 3-4 weeks. I had to run the cards at stock settings but it worked.
Believe me I was sure that PSU was going to pop at any time but it did'nt, from what I understand Corsair PSU's can output more wattage than their ratings state they are capable of.
I'd say you have nothing to fear.
Have Fun !!
that thing is playing golf like a CEO, instead of working rofl
get like 6 HDD's
. great rig btw
Not new to Overclock.net
Originally Posted by falco216
PSU calculator says 753 watts under full load.
The wattage that eXtreme Outer Vision's PSU calculator displays will change depending on a few different settings, especially Capacitor Aging. The more aging, the more wattage it'll display.
But, if I may ask, how do you "spread out the load over the two rails"? My PSU has 3, but I'm just confused as to how this can be done. I've never heard of such a thing, and so this has really peaked my interest. I want to give it a try.
1 - 20 of 26 Posts
