1 - 20 of 29 Posts
· Premium Member
This may be a different form of throttling.... i.e. faulty temp sensor
Reactions: FXTOi7
· Premium Member
Originally Posted by mikepahl318
I thought CnQ is the only power throttling setting... what else would do this? I cant seem to find anything.
Nope. My cousins 1055T was doing the same thing because the minimum power state wasn't set to 100%. Give it a shot.
I dont see the option to set it to 100%. i can only choose Active or Passive.
On both settings it drops to 1000MHz
Choose the performance option in the power settings.
· Premium Member
Didn't even think to look at your board. Yeah I wouldn't even be pushing 4GHz if my board didn't have some kind of cooling on the power side.
Get some of those little heatsinks and plop them on and see if it makes any difference.
Or for the time being try to find a way to jury rig a fan to blow directly on them and see if this still happens.
Discussion Starter · #18 ·
Any links to some heatsinks you would recommend? any guide to doing this?
· Premium Member
I don't have any clue as to how the proper way to do it would be but this Enzotech kit seems to have good reviews.
I would see if that helps and also try to get some airflow to them while you're at it. Not sure how the Antec 300 is set up but there's got to be some way to mount a fan to blow near the VRMs.
Hope this helps.
1 - 20 of 29 Posts
