I'm having an issue where my 1070 (Asus Strix will no longer idle below 911MHz (clock) and 4007MHz (Memory).
I have attempted:
- Googling the issue (most users reporting the issue were able to resolve the problem after uninstalling this program or that, none of which I have installed to begin with)
- changed the Power Managment Mode in nvidia control panel from "Optimal" to "Adaptive"
- Un/Re-installing Asus Gpu Tweak II
- Installing/ Unistalling the newest version of Asus PGU Tweak II
- Installing/ Uninstalling MSI Afterburner
- Updated to the latest nvidia drivers
- set both my monitors from 144Hz to 60Hz
- disabled secondary monitor and ran only 1 monitor at 60Hz
- Performed two clean installations of the nvidia drivers in safe mode using DDU from guru3d
- attempted to change the Performance Level from P0 to P2, P5 and P8 using nvidia Inspector (setting P-State does not apply however, it remains at P0)
I posted this in the 1070 Owner's thread but no one knew a solution. Any help is appreciated and will be repped!
I have attempted:
