Ok so I finally made my upgrade to the GTX 260 Core 216 and I must say I couldnt be happier. I used my step up program, however, so I couldnt bench the 260 against my old 8800gt's. Thats where 10acjed's PNY 8800gt's in SLI came in handy. I asked him a favor of benching them against each other and we did. The rest is history. We have basically the same setup with a Q6600 at 3.4Ghz and a 750i FTW board from EVGA so I thought this would be a great idea to bench!
But with our tests we decided to bench in 1680x1050, as that is the resolution we play at and we figure most of you play at. Let the results begin.
10acjed's GPU/CPU Settings
First off we start with the old standard 3DMark06 on our PC's. Settings are as shown:
10acjed's results:
My results:
So we already see the GTX260 pull ahead of the old SLI setup.
Now we move on to 3dmark Vantage
Settings:
10acjed's results:
My results:
As you can see he scored higher on the CPU end (weird but i'm guessing its cuz he is on an 8x multi? and i'm on a 9x?) But my GPU score was around 600 points higher.
I will update this with more test results when I get back with him.
10acjed's results:
My results:
Settings:
10acjed's results:
My results:
