1 - 14 of 14 Posts
Hi guys!
Slowly I started again after one year in a work.
Asus Rampage V Extrem
Core i7 5960X
GTX 980Ti Matrix Platinum SLI
HyperX Fury 4x4 Gb
HyperX Predator M.2 SSD/240Gb
HyperX Savage SSD/240Gb
Super Flower 1000W platinum
Thermaltake Core P5 case
Pacific PR22-D5 pump
Pacific RL480 radiator
PETG hard tubing
& fittings
The original case.
[URL=https://lh3.googleusercontent.com/-rdoNxGTg-nA/Vwann4y0z9I/AAAAAAAAL5I/SyJlWIUFduwlz3S4JsdlV8ShAPqTTuWkgCCo/s640-Ic42/IMG_8425.JPG]https://lh3.googleusercontent.com/-rdoNxGTg-nA/Vwann4y0z9I/AAAAAAAAL5I/SyJlWIUFduwlz3S4JsdlV8ShAPqTTuWkgCCo/s640-Ic42/IMG_8425.JPG[/URL]
[URL=http://www.overclock.net/content/type/61/id/2764863/][IMG alt=""]http://www.overclock.net/content/type/61/id/2764863/flags/LL[/URL]
The first step is vga bracket makeover.
preparing for the new vga braket
Discussion Starter #5
Today I went on the radiator grille design. This time, the LED lights were installed.
Proba:
The LED lighting will work in RGB Controller
Discussion Starter #6
The back panel first step: fan grill designe. The material PVC foam sheet.
The back panel is finished.
ram cover.
Phenomenologist
last 5 screenshots are indeed gorgeus, as a fellow RoG owner myself, +rep to you good sir!
Discussion Starter #10
Many thanks for recognition, I am a fan of ROG, now 10 years.
1 - 14 of 14 Posts
