May 12th, 0:00 UTC - May 17th, 0:00 UTC
Official Team Stats
Project Specific Information:
upload server IP: 5.9.17.234; 2a01:4f8:160:91ef::2
- The GPU apps for Amicable Numbers will max out one CPU thread at the start of each task as it loads the task into memory
- Each GPU task will use a large amount of system memory, depending on the GPU that is running the task. For example a Radeon VII uses 8GB of system memory per task
- You can tune the tasks on your Amicable Numbers account page: Account->Preferences->Project
- Max # of CPUs for this project (for CPU tasks)
- Kernel size for AMD/ATI and NVIDIA GPUs
app_config.xml:
<app_config>
<app>
<name>
</name>
</app>
</app_config>
*Note* app_config.xml is currently empty, and will be updated if there are any optimizations for the project.
