Much as racing stripes provide a small torque & horsepower boost, RGB clearly improves static pressure performance.Could anyone give me a hand here. I am a bit confused. I was looking at the Eloop X Argb fans. And noticed something interesting the B12-P regular at 2K RPM supposedly generates 2,240mm H2O. While the RGB Eloop X at the same speed is advertised at 3,020mm H2O. But they are literally the same fan. Just One has RGB. Is this just different testing protocols?
I'm curious about the test build colorway, however, as black/red multiplier effects often corrupt manufacturer testing data, and distinguishing between the two variables isn't easy.
Jokes aside, I'd confirm the two fans are, in fact, otherwise identical before looking for an answer elsewhere. If so, I'd then query Noiseblocker. Perhaps their testing methodology has evolved between product releases, but regardless, they're certainly your best resource.
