1 - 3 of 3 Posts
First off, I have an Antec Darkfleet df-85 case. Second, I bought a Coolermaster SickleFlow 120mm fan to put in the side panel of the case. However, I can't figure out how the fan screws into the side panel.
If you haven't seen the case, the side panel looks like this: http://i56.tinypic.com/34do9s5.jpg
Theres 2 holes where the 120mm fan goes, but they are too big for the screws that came with the SickleFlow. There are two other things that look like holes, but they're just little indentions.
Any tips or help would be appreciated. Thanks.
Originally Posted by jon5270;13052273
There are 2 white grommets that go in those holes that came with the case. They are for vibration dampening. So look in your accessory box and you haven't found them yet.
Oh wow.. and if I don't have those two grommets I suppose I can't install a side panel fan? Without tape or something I presume..
1 - 3 of 3 Posts
