Hello wondering if anyone as any trick or can help me out. Just got a second set of ram one is a gskill and one is a oloy both are dual rank samsung by cpu z.
3600 cl14 - 14 - 14 1.45v for both.
My setup:
12700k
MSI Z690A ddr4
2x16 oloy + 2x16 Gskill
First boot with the second set failed then i enabled XMP and tried many time to boot then got it to boot at 3600 gear 1 at 1.4v vccsa and 1.5v ram all the rest is stock.
Tried some occt ram and other mem app and everything was running fine even rebooted without issue then i tried to reboot and lower vccsa and it never wanted to boot again at gear 1 even with vccsa at 1.45 and ram at 1.52.
I can boot at default xmp gear 2 without any issue for some reason. But can't even boot at 3000mhz cl14 - 14 -14 at 1.40v vccsa and 1.5v ram
Just looking the most performance for gaming and my BOINC / [email protected] task.
Kinda lost here seem like a software issue or maybe the memory learning option i can't understand what it does.
Thank you
My setup:
12700k
MSI Z690A ddr4
Thank you
