12v+ rail change
440 Views 12 Replies 5 Participants Last post by  The Fryer
this has me going insaine.. my 12v+ rail keeps changing up and down. no load it is at 11.71v under max load it will go down as low as 11.26v then come back up to 11.35v and stay. my psu gets a little warm but not bad at all.. is this normal to have that much load vs idle voltage?
1 - 13 of 13 Posts
Get a multimeter.
The onboard sensor sucks.
Originally Posted by The Fryer View Post
i got one... dont know why i didnt think of that....
Pinouts are in sig....
Black wire = GND
Yellow wire = +12v
Well, if the voltages ARE indeed that low, I would think about replacing the PSU. Mad Dog is not really a respected PSU manufacturer.
Their booze aren't that great either
ok my digital multimeter says 12.02 idle and 11.76 full load on cpu and gpu.
Not great but acceptable.
so then i gess i should replace soon befor it gets horrid on me.
hear is what i am thinking..
http://www.newegg.com/Product/Produc...82E16817341023
http://www.newegg.com/Product/Produc...82E16817139005
i like them both and they are single 12v rails.
I have learned that OCZ PSUs leave something to be desired. Some models are better than others, but most get unstable as you approach peak output.
This would be the best bang for buck PSU - http://www.newegg.com/Product/Produc...82E16817139006
This Corsair will easily handle any upgrades you make in the future, including an entirely new build. The price tags is pretty good also
The Corsair you linked is also a great choice.
on a 8800gts u could just get corsairs cheapest psu im getting a corsair 400w for a friends build with a 4830 its $44 shipped after the coupon code.
i probly could but my card says Minimum of a 400 Watt power supply.
(Minimum recommended power supply with +12 Volt current rating of 26 Amps.) i have a 525w right now with a 26 and a 30 amp 12v rail and with everything going it just caint do it so i figure why not go heigher than i need.. right now i have 4 80mm fan and 1 120mm 150cfm fan rated at 1.5amps, plus my vid card, oc'd 5200, 2 dvd drives/burners and 2 sataII. i max this thing out when i get a good load going..
1 - 13 of 13 Posts
