1333MHZ DDR2 Memory for my setup
909 Views 19 Replies 7 Participants Last post by  Sleazebagger
Which is the best 1333MHz DDR2 memory for my system in my sig?
1 - 20 of 20 Posts
No such thing as DDR2-1333MHz. It just means your board can support DDR2 that's overclocked that high. I would get the DDR2-1200 G.Skill Tridents. They're known to overclock high.
Sorry, I meant 1200MHz. AFAIK, that is the upper limit of DDR2 right?
Correct.
http://www.newegg.com/Product/Produc...%20(PC2%209600)
Is the Trident already the "best"? I hate the fact that OCZ cannot produce those PC2-9600 chips.
Yeah... but on the other hand I've been running my RAM at 1149mhz for a year now... I doubt 50mhz is going to make a major difference...
I'm rocking OCZ reapers
Oh cool.
Any thoughts on this Acoma_Andy?
Bump!
Can anyone help me on this?
Well the Low Voltage DDR2 1200mhz sticks from OCZ or G.Skill are probably going to be the way to go as I can't find the Team Xtreme sticks anywhere.
As I told you, the G-Skill 9600's are great.
Ah. Where can you find cheap G. Skills?
The cheapest I could find were Blade LV 1200mhz for $150
Though, if voltage isn't an issue, nor heatspreaders. Amazon has a deal on 1200mhz Reapers.
These two kits of FLEX LX & Team Xtreme's were the 1333mhz capable kits.
Actually, I'm specifically looking for those blades for a LOOOOOOOONNGG time already. If you observe in the first link you gave me, they're out of stock until now.
I'm looking for best performance RAMs.
Well those Team Xtreme's will really do alot. But it takes some serious voltage and they are only 2x1GB.
But as you saw from the XS thread, they can really crank out the Mhz.
yep the teams are great for OCing,i had two sets and each did ddr1400
d3fct,over at techpowerup forums has a kit for $75.
but the best 2x2GB kit is the g.skill pc9600's and most will do 1300 easy.
$149 at newegg.
G.Skill pc9600 Pi's
$149 at newegg.
G.Skill pc9600 Pi's
Ah, so the G. Skill is still better than those Team Xtreems?
i think so for everyday use.you have 4 gigs and they only require 2.1 for 1200
so they dont get hot.but if its just extreme memory OC's and going for high fsb
action those teams are awesome because they are D9 GKX's and they love voltage.
G Skill PI DDR2 1100 works well with this board
1 - 20 of 20 Posts
