The current power limit or limit on power consumption doesn't make a difference in terms of how stable the CPU is around 220-230W, at 85C, all-core, 5.9GHz. A 105C limit with a bit of overshoot at 110C is perfectly fine.
LLC Saturation only helps to boost voltage a bit higher to 6.0GHz for undervolted LLC, such as LLC8, at 1.25V all-core, 5.4GHz. However, it requires both a very good CPU and good VRM, otherwise, it won't work. My CPU crashes straight up with LLC8, LLC7, LLC6 with 1.44V overdrive for 6GHz. The voltage curve for other frequencies is too low. When the CPU runs with borderline LLC5 + Saturation above 40A, the 350W 105C thermal throttled voltage is 1.40V, which is even higher than Adaptive voltage 1.33V.
It's still the combination of LLC, TVB, and Adaptive + Offset voltage that makes a difference. The CPU cannot be stable when the voltage is lower than 1.42V at 5.9GHz, 85C. But there are only two points of effective offset voltage: the point of 6.0GHz, 1.44V, and the point below 5.7GHz, 1.35V. Other frequencies, such as 5.9GHz, 5.8GHz, will be affected by LLC. 5.4GHz is completely ineffective, no matter what the offset value is. LLC5 gets 1.412V at 5.9GHz, which is not stable at 85C, while LLC4 gets 1.426V at 5.9GHz. This also results in 1.41V at 5.7GHz, which can be offset to a lower voltage, but I would rather use a constant high voltage instead of a constant undershoot and overshoot due to higher LLC.
There are only three points of 8-Pcore TVB as well. Anything higher than 85C, I can only set 5.7GHz TVB, or I could have set more points, such as 5.8GHz at 85C-100C, then 5.7GHz 100C-105C.
