1 - 6 of 6 Posts
Not New to OCN
Hey guys, I figured I would share a quick "tool" I made to easily power my water cooling pump from wall power since I'd imagine others would like the idea.
I recently dove into custom watercooling, and it became apparent that powering just the pump through the PSU was a hassle. It's a pain to disconnect everything in the PC, plugging in the jumper into the 24pin, etc. Something that I ran into as well is my HX750 doesn't like to be turned on momentarily and then back off again. It didn't like turning back on after that, so I would have to unplug power into the PSU, wait awhile, and then repeat the cycle.
So I went to Amazon and ordered a 60W, 12V power adapter used for LEDs for $9, a LED strip on/off switch for $3/ea, and some 4 pin PWM entension cables for $1.5/ea. The power adapter and on/off switch plug in like normal, and I just cut the 4 pin fan cable and end of the switch, soldered together, and it's done. So now I can easily power my pump with an on/off switch without unplugging anything else in the PC.
I might have been able to get away with a 24W (2A) adapter for a little cheaper, but at least I know 60W will always be enough. I think it will be worth the overall $14 cost!
As a bonus, you can use it power a PC fan on your desk to cool you off in the summer!
Reactions: spinFX
I honestly wouldn't try to pull all 24 watts out of a 2amp power supply, but that might just be me.
I'd look into getting a 60w one, they are still under $20USD
Since I'm currently looking into running the rad(fans)+pump externally, i plan on buying a small weird(maybe a 2U psu or an SFX psu) and have it turn on/off with the system. Via the spliced sense wires.
New001
Nice one OP, that is handy indeed! So far each time i've pulled my loop apart, i've pulled everything apart to do thorough cleaning etc, but i can see one day I will need sometihng like this. As you said, in a tight build it can be a pain to remove the atx and cpu power, along with unplugging everything else in the system!
I use one of these too, it's great for leak testing your loop. I got mine with an external CD drive enclosure.
Old and Decrepit
300 watt I yanked from a vintage dell and put a 50 cent switch across the pins to start it. Cut all the rest of the leads off and just left a single 12V molex hanging.
What ever works, OPs idea is great too. I also find it easier to use something other than the PSU you will be using in your build while filling and leak testing.
1 - 6 of 6 Posts
