1 - 10 of 10 Posts
Bios 1407, not sure what has been changed.<br />
<br />
<br />
<a href="http://www.diskusjon.no/index.php?showtopic=639612" target="_blank">Here</a>
I'm running 1405 right now, do you know of anything different in 1407 yet?
The highest official one is 1305, do you guys trust these 3rd party ones?
1405 is working better than 1305 for me, for some reason i can get the same overclock at about .5 volts lower, unless i messed up big time before.
Discussion Starter #5
Found some info on it.<br><br><a href="http://drivers.softpedia.com/get/BIOS/Asus/Asus-P5W-DH-Deluxe-BIOS-1407.shtml" target="_blank">Link</a>
I just installed the 1407 bios and it says I have an unlocked multi now...<br />
We'll see about that.
I have unlocked multi too. It orginally allowed me to unlock from 6-22. I set it to 400 * 10 and restarted. It then reset and said I could only set 6-8. Darn.
1407 is the official version. You can find it at <a href="http://support.asus.com/download/download.aspx" target="_blank">http://support.asus.com/download/download.aspx</a> Just search for the mobo. Motherboard -> Socket775 -> P5W DH.
Reactions: theking
Thanks for the link, oh also is it a good idea to raise the 6400 multi to 9?
you won't be able to unless you have one of those engineering samples with unlocked multipliers. the only thing you can do is unlock them downward with the e6400.
1 - 10 of 10 Posts
