1 - 4 of 4 Posts
I am looking for a 140 mm fan duct that doesn't look to bad, I'm going to paint it black if it isn't already anyway. I have found a bunch from 80 to 120mm fans but nothing any bigger.
Thanks in advance for help.
I made my own 120mm fan duct from clear acrylic tube, 4.5 inch, the 140mm fan is I think 5.5 inch, I know where you can get 5 inch or 6 inch tubes, maybe you can make some kind of 140mm duct with that. estreetplastic.com
1 - 4 of 4 Posts
