1 - 17 of 17 Posts
I love the jump from a 19 to a 22 and there so reasonably priced now... check the Deals section too!!!
It's a huge difference. I say go for it.
You will get about 20% more viewable area going from a normal 19" to 22" WS. Check my FAQ for numbers.
i liked my 22 alot more then my 19. I would def get one.
Originally Posted by PCDELCARIBE View Post
2 question
1)8800 gts 320 mb is enough for run actual games (full graphic details) in 22 display with native resolution ?
2) what best ? 2 x19" or 1x22 ?
1) yes, plenty. The memory size doesn't have an effect until 1900x1200 resolution.
2) Depends. For some games (Supreme Commander) and apps (Photoshop) that support two screens, 2x19" is better. Just for gaming, 22" is usually better.
I have a 22" and 19" for best of both worlds! Since they are extremely close to being the same height, it works out great.
I neeeeeeed a 22" monitor, but price per inch aint great, and worse after 23" and almost double to 24" from 22".
I have a 19 now, and it is absolutely fine for gaming, although I could have so much more on screen with a 1650x1050 resolution. The problem being that I would need to upgrade PSU, upgrade CPU, upgrade Mobo, upgrade Gphx and to top it off, buy another OEM Vista copy.
If it wasn't for all that, I'd go 22"
1 - 17 of 17 Posts
