1 - 4 of 4 Posts
i put 2gigs corsar xmscspt and it mad me reactivate windows, never happened before, i know if you make major hardware change like cpu,hd ,never did it with ram is that allways the case any comment thanks
that sounds kinda off, just a question, sorry not to sound degrading but did you put the biggest ram stick in the first slot?? i know a lot of problem with ram and stuff will come up if you put in one of the smaller ones first, oh and make sure your pc can handle it..........just a suggestion
i had 2x512 patriot and went to 2x1gig xms both pairs d-c
I might have tacos tonite
My guess would be you have replaced a few other things since you first installed, and the ram was enough to trigger the re-activation.
1 - 4 of 4 Posts
