You want silent, stick with larger fan psu's, 120/140mm.
What size are the fans in that OCZ?
Nothing much you can do without opening it up.
Originally Posted by Havegooda ![]() Eww, 80mm? I thought most 800W+ had at least a 120mm... /me <3 140mm on his TT 1200W ~Gooda~ |
But the greatest problem with this power supply was its temperature. We suspect that because of its reduced size and the use of an 80-mm fan â€" which is too small for a 1,000 W power supply â€" this unit would overheat. Our suspicion proved to be right. With other power supplies we tested the power supply temperature was only one to three degrees Celsius above room temperature â€" for example, 47º C when the room temperature was 45º C. But with this power supply this didn’t happen. On the first test the difference was of five degrees, on the second test the difference was of four degrees, on the third test the difference was of seven degrees and on the fourth test the difference was of nine degrees. But the real problem was when pulled the full 1,000 W from the power supply: the unit reached 68º C while the room temperature was of 49º C. |
A feature we could see in action was the fan speed changing depending on the power supply temperature. But since this unit works at very high temperatures during our tests its fan was spinning at full speed all the time, producing a very loud and unpleasant noise. |
