1 - 20 of 23 Posts
I could try wasn't bothered. Well I'm afraid because of my temperatures. I'm using stock cooler ;/. But it seems nice cos its working on like 45% on full load another thing is I got ****ty E8500 which may bottleneck
Well Slave, thx
Btw do you have any clue which is critical temperature for 5850?
I'm using profiles to switch back to stock clocks or higher clocks when I'm gaming.
So when I'm idleing on stock clock its at 45C and if I jump to 900MHz it turns to 55. But ingame its fine at 65-70 I assume since fan is smart controlled to keep it under 70C and it works on around 45%.
Also my last Graphic card was 9800gtx /Rip
Originally Posted by Shame486 View Post
Well Slave, thx
100*C+ is critical temps
anything below is still safe
I'd say no more than 85 on the core for 24/7 and the VRMs are built for 130, so about 100 here.
And BTW, your CPU is a bottleneck.
Discussion Starter · #8 ·
Thx on fast reply but,.
I find it as torturing hardware :/
I had 9800gtx on stock clocks and nice airflow. It used to idle at 60C duo my blindness I didn't notice that fan wasn't working correctly. Well it still had solid 75C on full load and then Iv custom adjusted fan control. Temps were nice then actually but noise level OH LAWD!. Sadly enough 2 weeks later graphic card totally died. When my pc booted up it just showed binary code and wasn't even able to boot up into Windows + some weird artifact across the screen. I don't want to experience again :/. I bought 9800Gtx back in 2007 also
Discussion Starter · #9 ·
Yeah Iv tough same, tried to overclock it to 4GHz but with this mobo not possible <.<, every time I set fsb from 400 to 401 it just gives me Error bad overclock returning to last stable overclock bla bla... As its 775 Socket I guess Ill have to go for Quad
I'd just jump directly to an i5. You wouldn't see enough performance boost from a Q9xxx. And I know the feeling about the OC. 485 FSB and my mobo craps out. For an E8200 that's only 3.88. Then again, 3.88 is better than your 3.8 GHz. I got the most bang-for-the-buck.
Yeah, that's the problem for us 775'ers. No upgrades without new mobo. And with new mobo comes new RAM. And with new mobo, most of us will need new CPU coolers.
depends.....most x58 mobos have 775 cooler mounting holes AFAIK
But the coolers can't necessarily handle the i5 @ 4 GHz when they're bought for a C2D @ 4 GHz.
Discussion Starter · #15 ·
Yeah like mine
But I'm looking for new solution. I saw nice thermal take Turbine Like cooler.
Great look also great cooling performances - Thermaltake SpinQ VT
And about RAM. Aren't there hybrid mobos that got 2 slots for ddr3 and 2 slots for ddr2?
Well Slave, thx
Once at 1000mhz Core you can experience instability around 70c
Anyways is there any aftermarket cooler for 5850?
Prolimatech MK-13 or Thermalright T-Rad2
Thermalright VRM-R4
Profit.
Some people use the AC TTP, but it's not build for this kind of heat.
Discussion Starter · #19 ·
Thermalright VRM-R4
Profit.
Thank you. Will defo look for those next month ;9, Iv spent enough already for this mont
1 - 20 of 23 Posts
