1 - 15 of 15 Posts
Stupid question guys. I want to add ssd to my msi ge76 laptop . Is it the m.2 NVMe Solid State Drive i should get ?or what size fitts in the laptop?? Thx
The owner's manual (usually on the setup disk that comes with the laptop), or the MSI site should tell you what is compatible. I think it will take an m.2 NVME drive, but there are a couple of form factors - you want to be sure it will fit the slot.
Thx
H₂O Aficionado
H₂O Aficionado
No, the storage drives don't have to match. Unless you want to run "RAID" but I assume you just want to add storage.
Discussion Starter · #8 ·
Yea just add storage. Now i have to figure out what slot the current ssd is in. If I should get a gen3 or 4 for speed.
I would guess that current drive is gen3, so if you decided to get gen4, you could move the original drive to the other slot (if it is in the gen4 slot). Of course, gen4 doesn't add much if it's just providing more space to put data. You could get a gen4 and clone your boot drive and software to it, and use the gen3 for data storage. Not sure the speed will be worth the effort..:)
Overclocking Enthusiast
I would go with an Sk gold P31. They are on sale at amazon right now. And it is basically the fastest Gen 3 ssd you can get. Trades blows with some gen 4 ssds in load times. And it is one of the most power efficient. So it is perfect for laptops.
Reactions: olllian
Discussion Starter · #11 ·
Whats the easiest way to clone a ssd ? Dose the O.s still work perfectly after a clone?? If I decide to go with a faster ssd to have os on. Thx
Unless you've got a million and one programs which require online activation, I'd do a clean install on the new SSD. That said, if you're just after storage space, just leave the OS on the current NVMe, pop in a second as storage.
+2 that. I have the P31 Gold in my laptop, its nutzo fast and gives amazing battery life! TRIM works great and absolutely no complaints!
A lot of people use Macrium reflect free edition. Or Clonezilla. To clone their ssds. However i do believe that SK also has a data migration tool. That you can download off their site.
It might be best to do a clean install if you don't have too many things installed on your system.
That's completely unnecessary. All the migration tools out there do a perfect job of migrating the partitions between drives.
OP: are you fine with the 2nd SSD being a separate drive letter that you move files to, or do you need to expand your existing filesystem to the new drive?
What are your main apps/games, or what is consuming most of your space (music/photos?) and do you feel comfortable locating those on a different drive?
1 - 15 of 15 Posts
