Just bought an i7 920 and Gigayte x58 Xtreme board and cause of the mobo my budget doesnt seem enough for 6gb kits so i ll try 3x1. Which ram kit should i use? this was the first.2nd one: Can i use 3x1gb rams without same serial(non-kit) is it going to cause much problem to my OC?3rd:2(3x1) or 3x2 which one performs better thanks alot
(i ll probably start with triple 1gb kit or non kit 3gb )
