Hi,
got my new hardware AMD 64 X2 3800+, Gigabyte K8N Pro-SLI, eVGA 7800GT, and 2x512MB PQI RAM.
My RAM seems to run stabil at (I do not know if this is good or bad for oc pros and I did not play with higher voltages) ...
[email protected] with CPU at 2400Mhz (RAM ratio 2/1.83 = 366), or
[email protected] with CPU at 2400Mhz (RAM ratio 2/2 = 400).
Q1: So I guess it is better to have a highe RAM freuqency (@240 in my case) than to have more agressive RAM timings but at lower speed (@220), right?
Q1b: Beside, I do not think that the "asynchronous" factor would make it worse?
Q2: In general, I run a "regular" partition for work and all other things, and a seperate very clean partition for games. Shall I consider any difference in oc-ing the two differnet partitons, or keep it the same. Btw, I do not need the last possible fps for gmaing or the max score at any mathematical benchmark test on my regular partition, I just want not to "waste" easy oc potential for my hardware without risking stability.
Thanks,
Bill
Thanks,
Bill
