1 - 5 of 5 Posts
I am an AMD man. I have a P4 478 2.8 HT Chip just sitting here in my hardware box. Should I build a system with it or would I be wasting my time?<br />
I have seen that some companies make boards that support the 478 chips but run on the new Intel chipsets...therefore supporting ddr2 and pci-e. ASRock is on of these companies, I called them and asked them how to get my hands on one of these boards and they told me they are only available in the Japanese market. I have seen them from time to time on ebay and they go for about $200 USD. If I were to pick up one of those boards on ebay would it be worth my time?<br />
<br />
<br />
<br />
Thanks,<br />
James
$200 for a 478 mobo? Bad deal. That CPU would be a major bottle neck for both the DDR2 and PCI-E. I would say stick with the older DDR and AGP and perhaps build a cheap folding rig out of it. Overclock it too of course, some of those 2.8ghz chips can hit 4ghz.<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" />
Sweet, thanx for the info, I have not run a Intel chip since socket 423, What would be a good setup to go with? I have 2 old server cases here a 20 bay and a 24 bay...they are bare naked right now but im thinking of doing a custom mod to the cases because they are so huge, I would want to water cool just because of the lack of case fan support on these older cases (they only hold 3 80mm case fans each) I also have a Kingwin 450W PSU sitting in one of the cases that would work for the p4. Any suggestions on a board to use?<br />
<br />
<br />
Thanx for any info.<br />
<br />
<br />
James
First: check my Signature<br />
<br />
Second: Go over to <a href="http://www.newegg.com" target="_blank">www.newegg.com</a> and get a Biostar P4m800<br />
<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813138262" target="_blank">http://www.newegg.com/Product/Produc...82E16813138262</a><br />
<br />
find some DDR, get a decent power supply and get folding!<br />
<br />
Also, make shure that P4 gets good cooling
yea... your current rig is WAY better. probably a lot less power consumption too.
1 - 5 of 5 Posts
