Howdy folks,
I have two quick questions with regards to my Nvidia 7800GS. I did a quick search and have trolled google but couldn't find the answer I was looking for.
1. Dual Monitor Support. Is there a way to force it so Windows recognises the 2nd monitor so I can have my desktop setup on both, but still as individual desktops\\monitors? If I use the Nvidia Control panel, I can setup the second monitor, but it will only "clone" or "stretch" the desktop (Forcing windows into thinking I have one big monitor). Normally you can just do this via the Control Panel by enabling the Secondary Display, but because the Nvidia software/drivers force Windows into thinking you have one large monitor instead of two seperate monitors, it doesn't give you that option. Is this something that a driver/BIOS flash would fix, or is that kind of setup unsupported on the card?
2. I am looking at OC' the card, and was wondering what the best tool/software was to use for that?
Also, could someone recommend what the best drivers are for the card (either Nvidia or tweaked drivers)?
