The only difference I can spot is the response time, seems to be a bit quicker on the second one (2ms vs. 5ms). I guess the second one is also a newer version probably, but other than that I would probably get the first one from what I see there.
Originally Posted by soulsonicforce ![]() Indeed, 24 inchers w/ 1200p are getting cheaper and cheaper by the minute, i believe the cheapest one on newegg is 260, and periodically, there will be great deals in open box (not for the faint of heart). There is also a bunch of great 24inchers on tigerdirect for cheaper than newegg even. I had one of the refurb gateway fhd2401 for awhile and was very impressed with it, although i would get the fhd2400 for the extra inputs, and height, swivel, and pivot. Heres a decent acer 23" with 1080p resolution for 200 bucks! Thats ridiculous. http://www.tigerdirect.com/applicati...406&CatId=3774 This page has plenty of 24 inch monitors that are the same price, if not cheaper, than the more expensive 22 you were lookin at. http://www.tigerdirect.com/applicati...c:3774|&Sort=4 |
