1 - 20 of 22 Posts
What the title says. Two GTX 680's 4GB edition from EVGA or 1 Titan from EVGA? Not sure if the titan is worth it for like 1grand which is like what 10% performance increase for 500$?
Originally Posted by BeardedJesus View Post
How can someone tell you if the additional performance is worth it or not. It's up to you.
This. We also need to know much more.
For me, I had the same question. But I choose a Titan because the only games I plan on playing across this year. None have official dates on SLi abillity yet. And I play at 5760x1080. So I needed that single biggest card for me because a single 680 I had at the time, couldn't keep up at 5760x1080.
Discussion Starter · #8 ·
So, three EVGA 670's, two EVGA 680's, one EVGA 690, or one EVGA Titan?
New Computer:
Intel Core I7 3930K
One Western Digital Black 2TB 7200RPM 64MB Cache Sata 6.0GB/s HDD (Thinking about getting one additional drive to RAID maybe? Idk)
Asus Rampage IV Extreme LGA 2011 X79 Intel Motherboard
ASUS Monitor VG Series VG278H Black 27" 2ms Monitor 120Hz LED backlight 3D ready comes with Nvidia glasses
Corsair Obsidian 900D Supertower Case
Swiftech H220 AIO liquid water cooling Kit
Two Sunbeam RHK-EX-BA Rheobus-Extreme Fan Controller Panels
CORSAIR AX1200i 1200W Digital ATX12V v2.31 and EPS 2.92 SLI Ready CrossFire Ready 80 PLUS PLATINUM Certified Full Modular Power Supply Unit
One SAMSUNG 840 Pro Series MZ-7PD512BW 2.5" 512GB SATA III MLC Internal Solid State Drive (SSD)
Promiltech PK-3 Thermal Paste
CORSAIR DOMINATOR GT 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 Desktop Memory
Two Noctua NF-F12 PWM 120mm Case Fan's for Swiftech H220
Sick build!!!!
I was in the same position as you a couple of weeks ago. I went the 2 gtx 680 4GB route. Just finished doing my build so haven't done any benching yet. I think you'll do good with either configurations. Just depends on personal choice I guess.
New Computer:
Intel Core I7 3930K
I would get the Titan as far as single card setup goes. It'll handle pretty much anything you throw at it with the monitor you're getting.
How long will you keep the GPU (s)? Do you use mods in your games? If you're staying @1080P, will be switching cards soon, & don't use mods.. I would get two 680's
Titan is a BEAST @1080P though
If you're moving up in resolution, want smooth game play, & don't plan on switching for awhile... Get a Titan
Both will play @ ultra high level, Titan will give you good FPS...
Titan FPS will be better on the low end & 680's on the high end. Titans will be smoother overall, but you probably couldn't tell. I know I can't. I just tried mine a few weeks ago. I tested one 670 vs. one 7970 vs one Titan. Of course Titan was better, but with moderate settings I couldn't tell the difference. 7970 Crossfire Vs titan SLI was a tad bit different.
You choose what your gut tells you, cause they all will ball out play the hell out some games. @ 1080P I would get the 680's & would try for 4GB models....
I was just going through that same decision. I decided on a Titan. The other options are faster, but Titan equals less headaches and less heat. And it should offer more consistent game play.
1 - 20 of 22 Posts
