1 - 6 of 6 Posts
Is there a switch box or something similar that I can use to hook up 2 systems to a single monitor and toggle between them?
You need a kvm switch
Reactions: Syrillian
If your unfirmiliar..<br />
KVM = Keyboard, Video, Mouse ... you then only need 1 do do all three for both PCs.
Belkin sells a two PC KVM with all the cables included. Cheap.<br />
<br />
<a href="http://www.amazon.com/gp/product/B0000899ZE/ref=pd_cp_e_title/104-5106555-1626310?ie=UTF8" target="_blank">http://www.amazon.com/gp/product/B00...626310?ie=UTF8</a><br />
<br />
If you look around you can find one that switches audio as well.
1 - 6 of 6 Posts
