3x 1080p on just two 460s might be a little bit too much when gaming, you might have to live without any AA
For those on a budget, or not wishing to worry about the power draw or heat output of a full-fat GF100 SLI setup, but still wanting to enter Surround gaming, the 2GB GTX460 presents an unrivalled opportunity to do so. Given the little extra cost of a 2GB card over a 1GB card, there is no reason now they are available to go with 1GB cards and risk a 'settings lottery' of whether a particular detail setting will push the game into single-fps territory. Obviously, for those running single screen systems, a 2GB card is just overkill. But as already said, for those wanting Surround on a "budget"… a pair of 2GB GTX460's for three cheap 1920x1080 or 1920x1200 screens can't go wrong. |
But the 570 takes less power, that he is correct at. And its much less hot.Originally Posted by Cyph3r;13121051
Oh yeah 1% is a huge difference. And the GTX480 is like £90 cheaper.
Good to have the author of that review here to explain.Originally Posted by Paradigm Shifter;13121039
I wrote that review.I also posted it here, but I'm not on much at the minute because I'm too busy.![]()
Three displays will run on a GTX460SLI setup, yes - in fact, SLI is required for nVidia Surround, while you can get away with one card with AMD's EyeFinity.
I really wouldn't recommend trying 1080p Surround on 1GB cards. It is possible, but you run into some serious VRAM bottlenecks that just kill performance completely. Remember that with 1080p Surround, you're asking 1GB of VRAM to cope with rendering 7 million pixels. No single monitor can give a GPU the workout that Surround can. If you were thinking of 1680x1050 or lower, it would cope better.
That said, if you've already got the cards, try it - it's not a bad experience, you just need to spend a lot of time tweaking settings so that you don't end up with slideshow framerates. MSI Afterburner and a G15 help too, so you can monitor in realtime the VRAM utilisation.![]()
Originally Posted by windfire ![]() Good to have the author of that review here to explain. And, I think the graphics subsystem in his sig rig speaks too. ![]() |
Originally Posted by tryagainplss ![]() if the OP is gonna spend a lot on a GPU setup for surround.... I suggest a 6990 or a 590 |
Originally Posted by Paradigm Shifter ![]() However, I wouldn't recommend overclocking the GPUs in a Surround environment; Surround gaming pushes the GPUs harder than single screen Furmark, harder than [email protected] I could Furmark @ 1920x1200 with the cards on 875MHz @1.025v, and Fold at 925MHz @1.025v... but gaming in Surround I couldn't get stable past 780MHz at the same voltage... and if I bumped the voltage up, heat quickly became a serious issue. I thought I had them stable at 815MHz at one point, but that proved erroneous; Just Cause 2 is one of the best stability tests in Surround, interestingly. While this might sound strange, I wouldn't recommend spending a lot on a Surround rig. At least, not on the GPUs. Buy the best monitors you can - they will last longer than the GPUs will. Also make sure they have DisplayPort, so you can switch between EyeFinity and nVidia Surround as/when the mood takes you. I strongly favour the Dell U2410for 16:10, or the U2311H if you want 16:9 (which I don't). |
