1 - 8 of 8 Posts
Hi All!
Thinking about getting a Megahalem and 2x GT 1850's for it.
I had read some reviews stating that these are not PWM compatible.
Since this is a popular setup, how does everyone have these connected. I was thinking of getting a Y splitter and connecting them to the board. Will the bios control the RPM's, or will they have a constant speed. If so is this an issue?
Thanks in advance!
Originally Posted by Rmerwede;15229982
Hi All!
Thanks in advance!
BIOS control is fine. It will adjust as long as your BIOS has the options for it.
Storage Nut
Originally Posted by firestorm1
i use mine with a y splitter connected to the cpu header. they will have constant speed though as there is no way to adjust them since they are not pwm.
I can adjust the speed of my 3 pin fans...
Storage Nut
how?
mobo header lol, it works fine for me, I just set it to silent mode in the bios...also there is an app for my mobo. YOu should have asus fan expert too.
hmm. maybe its board specific. when i got my cooler and fans i tried to adjust the speed. it was no dice. they still run full speed. but ill give that app a try though.
It is board specific. I had one Asus board that did it, then I upgrade to another Asus board and it didn't work.
1 - 8 of 8 Posts
