2000watts
638 Views 15 Replies 11 Participants Last post by  Oklahoma Wolf
1 - 16 of 16 Posts
No thanks
I've seen that before, I always thought it could be bigger
Originally Posted by The Master Chief View Post
http://www.performance-pcs.com/catal...ducts_id=26415
I want
It's just two 1000w PSUs in one. Common household wiring can't utilize it anyway.
Originally Posted by Ladiesman101 View Post
well
if you want a nice big powerbill get it
It's only going to draw what the rig needs from it.
Besides, this thing is a huge waste of money.
Thats nearing the limit of a household 120v line (20A, 2400W). This would throw the circuit breakers on many houses. That is, if you can plug in enough things to actually reach 2000W.
edit: most lines run 15A @ 120V, which only makes 1800W.
Originally Posted by Sheehanigans View Post
Thats nearing the limit of a household 120v line (20A, 2400W). This would throw the circuit breakers on most houses. That is, if you can plug in enough things to actually reach 2000W.
I believe current household circuits are 15A or 20A with most being the latter.
Don't forget that a 2000w rating is on the output side. You need to factor in efficency as well. A 2000w PSU under full load would be pulling around 2400w from the outlet!!!!
And yet, it only has 3 x PCI-E 6+2 pin and 2 PCI-E 6 pin connectors
This is also an unknown brand to me
2000 Watt? Psssh... That's pocket change. Here's something to feast your eyes on: Feast Away
That's nice, except it's larger than a mid-tower
That would be perfect for a folding farm!!
Well, just a guess but, if you need that thing probably won't be using a midtower to begin with. Just a guess.
It's also a MIG welder, not a PSU
The Epower 2kW is two mediocre Topower 1kW units crammed into one box. You'd have to pay me to take one, and even then I wouldn't use it.
1 - 16 of 16 Posts
