Hey all just wondering... I have a 2009 Mac Pro and I have flashed the EFI to the 5,1 so I can upgrade to 6 core processors and to 1333mhz memory....
Now question do i have to use ECC memory?
or
Can I use any kits of lets say 6 x 8GB 1333mhz ram and be fine as long as they are all matching kits?
So lets say I get my hands on 6 x HyperX Fury White 8GB DDR3-1333MHz CL9 DIMM not that I am looking at those sepcifically but just an option.... would they work or can I only use the server ram.....
second IF I can use normal memory what would the pros and cons to using either but not mixing them obviously.....
Thanks.
or
Thanks.
