I have been looking for a 200mm fan recently and found a dearth of comparative reviews on the latest selection. There are the good old 200mm Cooler Master Megaflow LED fans and Antec Big Boy, but then there are also some more mysterious choices by Xigmatek, Apevia, NZXT, Aerocool, Bitfenix, and more.
Personally, I am looking for a good case airflow fan, which generally means good airflow at low noise level, probably with some downvolting required.
Here is my personal experience, and I would encourage others to add. I would love to see some professional comparative reviews as well. So far, my opinions are subjective and have not been tested with a noise / flow meter. As a note, people who say that their fans are quiet because other components overwhelm their noise are not helping, because for all we know, their systems might contain a reference GPU with loud fans, an old noisy PSU, a couple of mechanical hard drives, and a number of cheap case fans at full blast.
- CoolerMaster Megaflow 200mm:
Decent airflow when downvolted, but the fan is definitely not quiet unless downvolted. I haven't owned it for quite a while, so details are now fuzzy. Some motor ticking noise in my fan.
- Bitfenix Spectre 200mm:
Very quiet, but not silent. Some electrical buzz at higher RPM / motor noise with a tiny bit of tonality. Would not be noticeable in a system with noisy components, but can be clearly heard in one of my cases until I turn down the RPM to 60-70% of maximum. Airflow is... very bad. A lot of it is going toward the edges of the fan in a radial direction. I can feel almost no air moving across my hand, holding it ~25cm away from the fan at max RPM. It also seems to push some air backwards. I don't recommend these fans.
Poor design in that these fans are intended for mounting as exhaust, in that they only have mounting hole "ears" on one side of the frame. Using long threaded bolts should allow to use these as intake as well.
- Antec Big Boy 200mm fan (came with my old Antec 902 case):
Decent airflow. Strong rush of air sound at high RPM. My unit had no noticeable motor noise.
- Bitfenix Spectre Pro 230mm:
This is a LOUD fan at anything above 500RPM. I had to run mine at 400RPM to be unnoticeable. At max RPM it was a hummy rumbly noise machine. I cannot attest how good airflow at high RPM was as I could never tolerate running it that fast. At 400RPM airflow was really measly. Hopefully the 200mm version is better. At least these fans have a very beautiful striking design going for them and multiple color / LED options.
