1 - 20 of 28 Posts
Hey guys,
Does anyone know where I can find a 200mm radiator in Canda, or that ships to Canada without tariff/custom fees? I am considering a 600T build, and I can't find a 200mm radiator for the front.
Or, if you know where I can find a 200mm to 120mm mount converter in Canada/Canadian Etailers, that'd be sweet too. I haven't had any luck.
Thanks.
Originally Posted by lowfat View Post
Aquatuning.us is your best choice. You pay taxes and brokerage at the time of purchase so you won't get any fees from UPS at your door. Shipping for them is also 3-4 days vs 7-10 days for purchases from FCPU or PPCS.
This is excellent. Thanks!
Just be vigilant. Aquatuning is not known for their proactive customer service. In stock on their website does not necessarily translate into in stock at the warehouse, and they do not tend to tell you if that is the case. I, and others, have also experienced situations where the estimate for the item to be back in stock is months away, yet they still do not inform you.
There are other options. Frozen CPU, for example.
Just make sure to choose USPS (United States Postal Service) as your shipping choice.
Do they adjust or inform of customs fees??
Why's that? I'm in Canada.
What do you think of this?? It has a custom made plenum for using 2x120mm fans to cover the 200mm area. Been thinking about selling it. I have a 600T and have been debating on upgrading to a 400mm for the front.
EDIT: I can second on Aquatuning not being very friendly or easy to work with. PPCs on the other had I do a lot of business with, and have had them basically order parts from Aquatuning for me.
I think i've decided to skip the 200mm and use a 240 instead.
200MM Fits just fine in front..u have to dremel the drive bay a bit to fit that out,,its easy.. check out my gallery,,i got 600t aswell.and I am from Van BC. you can get registered here www.thelettercarrier.com if you live near the States border in BC. They are in Point Roberts. You get your stuff shipped there, pay standard US shipping and cross the border pick it up..I go there all the time.. less than 200$ customs don't even charge duty. and the lettercarrier charges around 3.50$..
btw I got Phobya Extreme 200MM RAD from performance-pcs.com http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=59_457_667_975&products_id=31028
but canadian store is there too http://www.dazmode.com/ bit expensive IMO.
OK, lets think a little. Frozen CPU is in the US. USPS is the United States Postal Service. Postal does not charge brokerage fees. If the item is over $50, Canada Customs will charge the GST (15%) and a handling fee, $5 I think.
Got it now?
Yes, I use Dazmode all the time. Their selection of water cooling components is conservative though.
Got it now?
...because international postal charges relative to the American postal system is something all Canadians would know...
But thanks...
But thanks...
No no, you misunderstand me. "Got it now?" simply meant to ask if you understand my point, nothing else. Shipping costs from the US tend to be high, unless your order is quite large to make it worthwhile. this is where planning comes in instead of grabbing a piece at a time.
Dazmode is just too expensive, not good value.
Discussion Starter · #12 ·
Lol, sorry. It sounded like you were trying to be aggro.
Well, Dazmode doesn't seem overly expensive. And it seems like the shipping and customs from other Etailers evens out considering Dazmode is Canadian, and only 1 city over (Toronto vs Ottawa) I've always ordered from DM and it seems fine. Who has better deals than Daz..?
Hey guys,
Thanks.
Try the Koolroom here in Australia
http://www.thekoolroom.com/
http://www.thekoolroom.com/product/phobya-xtreme-200/
Discussion Starter · #14 ·
LOL, shipping from Australia would not only take about 46 years, but it costs more than my monthly salary. I appreciate it though. I'm fairly certain I'm skipping a 200ml anyway and seeing what I can do with a 2x120
You can mount a 240 up top without any modding. Or you can put a 360 up there with a slight mod and be good to go. If you havent checked it out already, we have a 600T owners club here at OCN. Link is in my sig, some amazing builds and all the pictures can be seen from the first post through links
Originally Posted by lowfiwhiteguy View Post
DazMode is a little expensive but his service is absolutely outstanding in my experience. I say support domestic business.
I do when the mark up is reasonable. Not the case here. The bottom line is that we really don't have a good supplier of water cooling components in Canada. While Daz Made has a fairly good selection, the chances of finding everything you are looking for remain slim. Once you have to buy in more than one place, the shipping becomes ridiculous. Add this to his high mark up, and Performance PCs becomes my store of choice.
Case ***der
Shipping from PPCS is way too much now especially if you want insurance. They use to be my first choice but now they are my last as shipping is generally over 2x what it is from Aquatuning.
1 - 20 of 28 Posts
