Hi all,
So, this is my attempt at benching cooling solutions, is has been a long (several months of my spare time) and arduous process, so please be gentle.
Hardware group picture:
Here are a few points, before I dive in this monstrosity:
The coolers that are compared in this are:
Setup used for all tests:
Settings are as described above. Using Dynamic OC Switching allowed me to maximize CPU usage lower threaded loads (Timespy runs), whilst having a sustained, and predictable all-core load under multi-threaded loads. Under that all-core load where DOS kicked in, the power drawn by the CPU was hovering around 210-225W.
For the tests, all fans for all coolers were replaced with Arctic P12 and P14 PWM PST fans, in order to evaluate the cooling power of the heatsink solution on it's own. (YES, I did dare to replace the fans on a Noctua cooler (HERESY!), although a case could be made it might give different results with its premium stock fans.)
All tests for the AIO and custom loop were done at 100% pump speed.
Tests were conducted using PWM signal for the fans, at 25%, 50%, 75%, and 100% fan speed, as well as the included Silent, Standard, and Turbo fan curves that came on the board.
All tests were done on the same Bios and chipset driver version.
Temperature was kept between 20 and 21 degrees Celsius, in the test room, at all times (climate controlled with AC and smart thermostats).
The thermal paste used for all tests was Thermalright TFX. (14.3 W/Mk rating)
For all tests, the temperature was recorded with HWinfo64, and taken as the average temperature of the last 5 minutes of the run. (many of those tests had to be redone because I missed that mark, RIP my free time)
For AIOs and custom loop tests, given their ability to "soak" heat for quite a while before getting to an equilibrium temperature. To palliate to that, Aida64's stress test was run for 30 minutes before each AIO tests, and for 60 minutes before each custom loop test to "soak" the respective cooling solutions as much before immediately starting the tests.
For the results, temperature is in degrees Celsius, and "Crash" is used to designate any problem with the test, ranging from straight up BSOD to Massive slow down of the test due to instability by temperature or over-temperature protection kicking in.
Now, the main course, the results and analysis:
212 Evo
As it was pretty obvious to most of you, the 212 Evo is nowhere near being able to keep over 200W under control. This test was mostly to demonstrate that trying to save 20-40$ on the cooling solution, on a nearly 1000$ CPU is not the way to go. Legendary king of value air cooling has a limit.
H7
That CPU cooler we saw in every build posts a few years back. Looks great, buck, unfortunately, results are pretty similar to the 212 Evo: not enough cooling power. Note that the cooling plate is scarily small on that unit, compared to the AM4 IHS... I was very hesitant to even test it.
H5 Universal
The H5 is the first, and only, single tower cooler, in this test, being able to somewhat "tame" the 5950X whilst drawing over 200W. You need to crank the fans to ridiculous levels for that, but it can! For gaming scenarios, that cooler could actually be sufficient for some cases, and with an undervolted 5950X, I could see it working. A better pick for a single tower solution might be Noctua's famous NH-U12S, which will surely beat the H5 Universal, and be enough for the task.
Tisis Core Edition
And we have our first dual tower air cooling solution. The Raijintek Tisis Core Edition represents dual cooler solutions on the cheap. I actually got mine, brand new, for what represents 45USD (provided it came without fans though). At that performance point, any "normal" fan speed is enough to get the 5950X under control, even with a single fan! The best setup definitely is using 2 fans, as 3 fans shows little to no improvements. For the price you pay, it is the cheapest entry realistically able to deal with an overclocked 5950X.
NH-D15 (S)
The king of air coolers, the NH-D15 (S). No need for introduction here, this cooler is, arguably, the best air cooler our there. And, at sub 100 USD, it is a force to be reckoned with. It is perfectly able to maintain the 5950X under control. And, has a bonus, this is using Arctic P14 fans. Not that those are bad fans, but the stock Noctua fans are actually better, and more silent that that. So, at 100 USD, you probably get better results than what you see here! As for the Tisis, 1 fan works, but 2 fans seems to be the sweet spot, with 3 fans barely making a difference over 2 fans.
280mm AIO (NZXT X62)
Our first AIO! And, unsurprisingly, it passed with flying colors. Results are a little better than the NH-D15, so we can safely assume that a 240mm AIO would land somewhere around a NH-D15, or slightly worse than it. Going for a push-pull configuration (4 fans) improves the situation a bit, but not by a lot.
360mm AIO (Corsair 150i Pro XT)
Our second AIO fares a little bit better than the 280mm. Which is quite natural, given that it roughly has 10% more surface area to work with (360mm x 120mm vs 280mm x 140mm). Again, we see a 5950X being completely kept under control, with a little bit of improvement by going with a push-pull configuration, over a push configuration.
Prosiphon Elite
Now, the oddball of the bunch: the IceGiant Prosiphon Elite. First of all: what a freaking chungus. I mean, this thing is one heck of a unit! If you think that the NH-D15 is big, this thing will dwarf it. I was legit scared that it would be too heavy for the mobo, but it actually comes with a very sturdy mounting solution props to them for that. Now, for those not familiar with that product, it is actually a cooler using an entirely different approach to cooling as we are used to. It's neither using traditionally heatpipes, nor a pump and waterblock. Instead, this bad boy uses nifty physic to turn the difference in temperature of the liquid inside it, into a "pumping" action. Turning is into some sort of AIO, without any pump noise at all. Theoretically, the more heat output of the CPU (and thus heat you input into the Prosiphon Elite), the faster the liquid inside it will "pump", and go through its 240mm-sized, quite thick "radiator" (it's a bit more complex than that, but I am trying to simplify). Although, this thing was designed (and will work a lot better) for very high area and high heat output CPUs (cough cough... hello Threadrippers!!!), it is interesting to see how it deals with a smaller and more energy efficient 5950X. And, the results are not bad at all. It fares a little worse than a dual Tower solution, but, given that it is silent, apart from the noise of its fans, and the truly unique look and inner workings of it, it really is an interesting solution, which is actually capable of dealing with a 5950X. The downsides of it are pretty obvious though: it's massive size, and it's price, at roughly twice the price of the NH-D15. Although, for that later part, the Prosiphon Elite's price is actually reasonable, if you consider that it is a cooling solution designed for multi-thousands of dollars Threadripper CPUs.
EKWB Supremacy Evo custom loop
Now, the custom loop. Does it work? Yeah, what question is this? Is it practical from a price/performance standpoint? Not at all. But is it baller? Yep. Basically, this is just overkill, and actually needed over an hour of 100% stress test to get it to reach above 60 degrees for the Timespy test, otherwise, the sheer thermal mass of the loop could literally laugh at how little that test impacted temperatures.
Optimus PC AMD Foundation custom loop
The same can be said about this block versus the EKWB Supremacy Evo. The difference is: it's pricier, and it performs slightly better. End of story.
Conclusion:
Don't cheap out on a cooling solution for a high-end CPU. Although, you don't need to shell out stacks of cash, at the sub 100 USD mark, the NH-D15 really stands out as a very wise choice for those who want the peace of mind of air-cooling, and knowing that their CPU will be handled. If the color scheme doesn't suit you, there is a chromax black version of it, or other coolers such as the Dark Rock Pro 4 and the Assassin III will probably land rather close to it in performance. If you are looking at AIO solutions, although I didn't test it, a 240mm is probably being able to handle a 5950X, and a 280mm solution certainly will. Basically, investing part of your budget for the proper cooling of a high-TDP, high value CPU is something to take into account when purchasing components.
Anyway, I hope you people appreciated/enjoyed/found this little write-up useful. It might be a little too much for what it's worth, but it's still something I wanted to do, and it represents a lot of my free time during this Covid pandemic.
Have a nice day to you all!
- I am no GamersNexus, nor any professional reviewer, I did this as an amateur, on my own, freely, and at my own costs, I might have made mistakes.
- I won't redo tests, nor test other coolers, this has taken me way too long to do, and I literally need a break from all of this.
- A lot of data was scratched, for several reasons, here are a few of them:
- Idle data was scratched, given that Ryzen cpus turbo in and out non-stop, rendering them almost impossible to be representative across all the hardware tested, especially given that I am running on a "normal" OS.
- I had noise data, but, given the noise pollution (construction work near my place in the spring, and AC noise getting picked up during the summer), I refrained from including it, and even stopped recording it for a lot of tests.
- Humidity level was varying way too much. My region had some long periods with and without rain, which made data a bit all over the place. It might have affected results slightly, sorry for that.
- No, I'm not running Prime95, I am an amateur, and I don't intend on degrading my CPU running all those tests. And, lets be honest, Prime95 is an unrealistic scenario for 99.999% of people, if not more.
- Some tests were removed, given that consecutive run-to-run with them gave results that varied way too much to my liking, or given that they lack the duration needed for proper testing.
- The 2 tests that were kept are Cinebench R23 30min run, and Timespy Stability test (20 loops), representing a case of more "work-like" usage, and a case of more "gaming" usage.
- Coolermaster 212 Evo
- Cryorig H7
- Cryorig H5 Universal
- Raijintek Tisis Core Edition
- Noctua NH-D15S
- 280mm AIO (NZXT X62, Asetek design)
- 360mm AIO (Corsair H150i Pro XT, Asetek design)
- EKWB Supremacy Evo block on a custom loop (details on that loop lower)
- OptimusPC AMD Foundation block on a custom loop (details on that loop lower)
- AMD R9 5950X (PBO and SMT Enabled, FLCK at 1900MHz)
- Asus X570 Dark Hero (DOS (Dynamic OC switching) Enabled at 60 Amps, 4.6GHz on CCD1, 4.55GHz on CCD2, at 1.225V)
- GSkillz Trident Z 32GB (4X8) at 3800MHz 14-14-14-26-42 1.475V
- Lian-LI O11 Dynamic case
- EVGA 1600T2 power supply
- AMD RX 6900 XT with EKWB waterblock and backplate
- Custom loop (ZMT Tubing, distro plate, two EKWB XE (60mm thick) 360mm radiators, DDC pump)
- 6 Arctic P12 PWM PST fans (push configuration on the radiators)
212 Evo
H7
H5 Universal
Tisis Core Edition
NH-D15 (S)
Prosiphon Elite
Conclusion:
