1 - 7 of 7 Posts
just as the topic states. i actually play bad company 2 for hours on end with no downclocking, but after like a hour or so of nfs shift, it downclocks
both are being run at maximum..
clocks are not at 850 atm, theyre 840.
If using drivers newer than 190, go to nVidia Control Panel> Manage 3D Settings> Power Management Mode> Set to Maximum Performance.
Might be the problem.
aha, yes, i had forgotten to change that after i reinstalled windows. thanks
i'd rep if i could...
You can, but that's a secret.
Discussion Starter · #6 ·
Originally Posted by KoukiFC3S
Hows your SLI performance?
i dont have sli...
but single card performance? good. maxed out any game with 50-60fps..
BF:BC2 gets down to like, 40. but still acceptable/playable for me.
1 - 7 of 7 Posts
