1 - 10 of 10 Posts
I have $250 to spend on xmas...oh what sould I buy? I NEED a gfx card. I was thinking something along the lines of a 7600GT and a mid-high range DFI board. Any more thoughts?
while the tower IS nice, my cnps9500 is more than enough until I go water. plus I also need a new mobo for a gfx card. What I am asking is, what mobo and gfx card should I buy for $250 (total cost for both!) I can go $20 over MAX but try and keep it as close to $250 as you can
Snerp has a SLI-DR with a killer chipset fan upgrade in the forsale section for $120. Take the rest and get the best card you can, but we can revisit that when you decide what MB and how much you have left to work with
why go from a 6800xt to a 7600gt, that's not THAT much of an upgrade... Hold off on the vcard till ur willing to spend a little more on it.
He's on an AGP MB and upping to a PCIe.
start on your watercooling...that'll last you 5-8 years while new computer componets will last you what....2-3 years if you can wait that long to build a new one?
1 - 10 of 10 Posts
