1 - 17 of 17 Posts
what a chip at the min im testing @4.5ghz 1.3v and still pushing upwards
what do temps look like?
42 42 46 49 were the core temps I'm hoping to hit 5ghz
RTX Sight Unseen
Using waht Block EK HF?
lol that is insane. 5.0 with under 45C under water. I might not even need to go to full water if I can hit 5.0 under 50ish with the h50. (ill prob go water anyways lol).
where do you live that you got yours early?
RTX Sight Unseen
Originally Posted by LiLChris;11926719
Safe to assume this is idle temps?
Certainly not under water. My 980x idles around 27c and its a much hotter chip.
Discussion Starter · #9 ·
Those are load temps I'm using a heatkiller block
Originally Posted by PanicProne;11927117
Damn, all these people getting SB chips early... I've been waiting for mine for almost a month.
I was going to get an upgrade for xmas...
And this will be my late xmas present
Have you tried running some gaming benchmarks or some single threaded benchmarks? I have read on a few review websites that you can get Sandy Bridge stable in prime / OCCT, etc, but anything that is stressful on only 1 or 2 cores isn't table.
Discussion Starter · #15 ·
pics as requested 4.5 ghz 6hrs prime stable will go for 5ghz tomorrow
Reactions: tconroy135
Have you been using OC tuner for that overclock or manual ?
Read somewhere that OC tuner would reboot and allow up to 4.5Ghz O/C without any 'manual' changes to voltage.
Thanks
edit: i'm planning to buy one, just trying to understand the way to O/C SB
1 - 17 of 17 Posts
