I installed my XSPC RX360 water cooling kit yesterday without a hitch.
My temperatures at between 50 and 60C on the die, in intel burn test @ 1.4V.
I am getting BSOD error: MACHINE_CHECK_ERROR (or something worded similar)
My current motherboard is the
ASRock Z68 Extreme3 Gen3
and I am using the exact same settings as
http://www.overclock.net/t/1190228/i5-2500k-asrock-z68-extreme-3-overclock-help-please
I have noticed that the on-die GPU is still showing up on my computer, do I need to disable it for higher overclocks?
Also I was running a screen off the on-die GPU previously, I am not sure if that was the problem,
will run some more stress tests with it unplugged.
Please help me out if you have any ideas as to why my OC is so low. I know a lot people can get 4.5V on Air with almost stock volts.
