I am running stable in Prime95, at least for 2 hours now. It seems like my cpu has topped out at around 2350mhz. I can do different combination to achieve it, like 215x11, 205x11.5 @ 1.75Vcore. But I just can't get past the 2400 mark, 200x12 wont do either. Prime95 shows SUMOUT error right away upon connection. My temp readings are 42 idle, 48 load, not too bad with air-cooling. I tried raise the Vcore to 1.85 but still the same error. So I dont think Vcore helps. My memory timings are 2-2-2-5. I dont know if it's the ram's fault. Cuz I can run it fine at 215FSB and 205 FSB. What can I do next??
_____________________
AMD 2500xp-m @ 2360mhz/1.75V
Abit NF7-S v.2.0
Corsair Twinx1024 PC3200XLPT 2-2-2-5
WD Caviar SE 80GB/8mb
WD Caviar SE 120GB/8mb
BenQ 52x32x52 CD-RW
Asus 9600XT 128MB @575/650mhz
Creative Live!Value
Cambridge Soundworks FPS2000 Digital
Thermaltake Volcano 12
Raidmax Cobra822 w/420w
Stepping: AQYHA 0431
Abit NF7-S v.2.0
BenQ 52x32x52 CD-RW
Creative Live!Value
