1 - 9 of 9 Posts
Some call me... Bifford
Originally Posted by --Filip--
how well would an Asus 6600 (128mb) and a 6800 (256mb) in an SLI setup work? (if at all)?
It won't, or at least shouldn't. SLI requires identical hardware.
I don't think so, the card have to identicle. How it works is each card renders half the screen, so if you stick a fast with a slow then you'll get screwy graphics, and that's assuming it would even run. Not only that, 6600 no GTs aren't SLi compatible.
ill say wait for the FX dual cores lol
no lol i mean that when the dual cores come out it will use SLi at full potencial! you should know dat lol!
Well I know that, but it just sounded weird because your answer had nothing to do with what he asked...
1 - 9 of 9 Posts
