Its a goof. Actually there is a lot messed up with that pic.
Why are you only getting 4.8V out of the +12V?
How are you running your cpu at 0.02V?
^^ this ^^
use realtemp and see if that displays anything funny, I had evga precision display a temp a 11,000 degrees earlier today, stuff happens, especially glitches
I figured it was just a goof, never had any problem before. Coretemp was reading temps correctly.
Originally Posted by MrPriest
I'm late here, but HWMonitor shows 206'C when I have CPUZ open simultaneously and then close CPUZ. Nothing to worry about!
If I run HWMonitor alone, no problems at all. This has caused me a big panic in the past also, and many people have experienced this problem.
I will say it again, many people experience this problem, definitely not a sensor issue at all! Don't worry yourself to death! Good luck and have fun!
Overclock.net
