Hey everyone I wanted to ask some advice on upgrading my netbook from 1gb 800mhz ram to 2gb 677mhz ram.
Currently there is a kingston 2gb 677mhz ram stick on for 30$.
The thing is when I bought my asus 1001p netbook I orderd a kingston 2gb 677mhz stick with it that has since died. I am now back to the original 1gb 800mhz stick.
The netbook runs fine now. I am worried that it might be a problem with ram comparability. The old Kingston ram lasted a good couple months with no problems, but then died for no reason. The computer screen would act weird and it would shut off. I Swaped back in the stock 1gb stick and it solved the problem. Do you think it would be safe to buy another 2gb stick?
I guess what I'm asking is was it likely a faulty ram stick that failed, or did the laptop somehow damage it.
