1 - 7 of 7 Posts
Originally Posted by quarter_breed View Post
im goin to be ordering a Cool Master Hyper 212 Plus from http://www.tigerdirect.ca/applications/searchtools/item-details.asp?EdpNo=4950641&pagenumber=16&RSort=1&csid=ITD&recordsPerPage=5&body=#ReviewStart
will any of these fans fit for a second fan http://www.tigerdirect.ca/applications/category/category_slc.asp?Recs=10&Nav=|c:802|&Sort=1
or can anyone recommend a second fan.. ill be OCing my 1090t BE x6 current idel temps @ 3.4ghz is idel 32c load 54c with stock AMD fan
If you need to add one more fan look at the yate loons medium and low speed.
I'm not impressed by Noctua's other fans, but the NF-12 is nice. It wont win any contests for cfm or static pressure, but it's adequate in both and surprisingly quiet at 1000-1200rpm. I prefer Scythes in general, but like the NF12 as my heatsink fan since I can trust pwm to have its way with it and it wont get loud. Worth it? I dunno. $30 is too much even for that fan, though. Can be had closer to 20. also I dont know how well it performs in push/pull matched with a dissimilar fan.
1 - 7 of 7 Posts
