I want to underclock my server[i/i] / uTorrent machine.
The clip on the cooler retention bracket (the black plastic on the mobo) broke so the cooler's tied on with zipties.
I want to run the rig pretty much 24/7 but for utorrent - nothing really more strenuous.
Is underclocking the same as overclocking. Reduce the multi / FSB and volts. run stress test, repeat.
I've got Win 7 installed. I'll turn off all of the eye candy in Win 7. I'll control the PC through Real VNC and my sig rig. The CPU's a XII 7750. The mobo's a Gigabyte GA MA 78GM US2H. 3 x HDs. 80Gb OS + 2x 500Gb WD Greens.
What CPU freq. should I aim for? 1.5GHz? Lower? Any suggestions as to what volts the low underclock will need?
Thanks a lot.
Mike
Thanks a lot.
Mike
