1 - 5 of 5 Posts
I have a display that only has one DVI.
I need cable or device so that I can plug the display to both PC.
the PC's don't need to be on at the same time so no simultanous ON.
You need a KVM switch. You can get them very cheap off ebay HERE (generally under $20). You local PC store will sell them as well, but they'll be around double the price I would think.
A KVM (keyboard Video Mouse) will allow you to use 1x monitor, 1x keyboard and 1x mouse for 2x computers. They usually have a button or switch to select which computer you want to use/view.
these KVM switches, are they problematic for gaming on the monitor?
btw I have eyefinity but will only need one display on both pc.
---> would something like this: http://cgi.ebay.co.uk/NEW-2-WAY-TWO-...item483d5c5765
be good, when I have connected to gaming pc hopefuly it works with eyefinity setup?
1 - 5 of 5 Posts
