The Drive on the left is the 2TB problem drive. One on the Right is a 500GB perfectly working drive.
Look at the pin in the center, one is pushed in. I barley even pressed it, and it just fell right in. Does anyone know if this is serious? Possible fix?
whats the model number of the 2tb i would say you should be fine if the drive still works iv seen them before like that and they have worked with out any issues i wouldnt be to worried about it however if the drive isnt work properly you should send it back if it has a warranty
yeah i would say you should be fine iv seen this happen before with alot of other drives and they all perform with out any issues after but that is on most hard drives the label will say do not push on cover so probably best not to push on it at all lol
