I'm about to order a new Solid State Drive(s). I just want to know would 2 Plextor 128GB in raid 0 be better and faster than 1 256GB Plextor?
I guess you forgot this is overclock.net? in the Pursuit of performance...Originally Posted by dragosmp;12995117
A single SSD is so fast there is no point in buying 2 identical drives for even more performance, unless you already have one and want to double up.
Quote:Originally Posted by dragosmp;12995117
The RAID will be worse as it will loose TRIM, but it will be faster than a single drive (at least until the flash-cells become very fragmented). A single SSD is so fast there is no point in buying 2 identical drives for even more performance, unless you already have one and want to double up.
He wouldn't lose TRIM on his motherboard. Intel released drivers for RAID with TRIM for the ICH10R controller a year ago.Originally Posted by CRAZYCAP;12995236
2 SSD's should see a good improvement in raid0 for speed. Dragosmp is correct you will lose TRIM but the garbage collection is so good now it shouldn't matter.
I thought that was complete speculation and it wasn't the case at all.Originally Posted by NuclearCrap;12995275
So TRIM frees up space? Could I just use Defraggler (Free Space) once in a while to free unused space? Or does trim do it automatically?Originally Posted by darthjoe229;12995265
TRIM allows your OS to tell your SSD which blocks of data are no longer considered in use and can be wiped internally, which advances garbage collection and boosts your speeds.
No they didn'tOriginally Posted by NuclearCrap;12995275
TRIM does it automatically. It finds files no longer needed and wipes them, so when the drive is looking for space to write it can do that faster. And DO NOT DEFRAG A SOLID STATE DRIVE! SSD's are actually SUPPOSED to be fragmented. I think you meant Ccleaner, and while this would work, why not let a background program essentially do that for you all the time?Originally Posted by DorkSterr;12995842
