1 - 3 of 3 Posts
Hey everyone, can anyone let me know if I can use 2x 3 pin fans with a spare Gelid PWM Y splitter cable to connect to the motherboard CPU Fan? Would this cause any issues? Im replacing my fan with two SP120's.
This is a picture of the connectors. One 3 pin fan would fill, Ground + 12VDC + Sense and leave the PWM pin blank. The second 3 pin fan would fill Ground + 12VDC only, leaving 1 spot empty on it for Sense where that pin is not present. The PWN pin again remains unoccupied.
The connection to the motherboard fills all 4 pins of course.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812718001
Thanks all. This is driving me nuts!
· Premium Member
Will work fine. Of course there is no PWM control so 12v constant power to fan unless you are using voltage control.
1 - 3 of 3 Posts
