2x 5870 or 1x 5970??
4142 Views 45 Replies 24 Participants Last post by  oxymorosis
Hi everyone
I am new to this forum and am currently in the stage of ordering a new pc, my budget is around £1800 could possibly stretch to £2k if needed.
As far as graphics cards are concerned i'm abit unsure on what to go with. I could either go down the CF 5870's or get a single 5970 and then pick up another one down the line. I'm thinking though that by the time I need another 5970 the 6 series will most likely be out and I may aswell just grab one of those.
I'd be using the setup for gaming (wanted to play crysis in v.high for ages now, and as a workstation for games design)
any comments on what you think would be best are all welcome and just the setup below in general.
thanks
1 - 20 of 46 Posts
I would Get 2 5870's since iwe heard there is some problems with the 5970, not sure tho
2x 5870 would run cooler, use a bit more power and be able to overclock further.
Also would look cooler in your case, and be easier to resale when you are ready.
Everything looks pretty good, you might consider the 902 instead of the 900. I have both, 902 is quite a bit better, and has black interior.
For gpu, I went with 5970 (though I have a 5870 on backorder for a month now) because if performance jumps between series to date remains constant, 2 5970s will still compete after the 6 series is launched, whereas 2 5870s would not. If you are only getting 1 5870, go for it, but 2 instead of a 5970 is a mistake in my opinion.
Lastly, you might consider a quality SSD instead of that R2E, most X58 boards will clock about the same for much cheaper. I would go with a P6TD, Boodrage, or EVGA, and put the savings into an SSD. You will notice the increased performance MUCH more.
Not true. We have tested it ourselves and found no issues with the VRMs. AT and LH got broken cards that need to be RMAd. Please revisit the threads.
The 5970 is working fine for people on this forum, and I trust that infinitely more than "review sites". OCN ftw.
Based on what, exactly?
The 5970 is a bit oversized and requires overclocking (including overvoltaging) to have a decent performance for the money. I'd say simply get two 5870s and that would work great on your mobo.
P.S. you might wanna think of using RAID0 in your new PC for a faster storage, or SSDs if you have the money.
2x 5870, every reason has been posted, cooler, more overclocking, easier resale and so on.
Having several GFX in your case looks awesome
The only thing that isn't wrong in your post is the size of the card.
I agree dopey
Yes I have a 5970 and its not bad at all,low temps,max clocks.I have some benches posted and also extreme burning test(furmark) to test VRAM all seems good to me.
Also heres a bonus I live in Canada and it was 250 bucks cheaper then 2x5870 and its just as fast.Also a 285GTX for Physx overkill all the way baby.
lol... maybe you're right
But seems you're overclocking (and overvoltaging) your own 5970 for about 25% ... Right?
Right now, your profile is pretty much near what two HD 5870's can do at stock clocks. So I'd say they require overclocking
Originally Posted by gerardfraser View Post
I agree dopey
A GTX 285 for PhysX?! Dude, overkill is nice, but an overkill that extreme is of no good. Get a GTS 250 for dedicated PhysX card, not GTX 285 omg..
Actually I have lots 285GTX cards,do not have a 250GTS,so not point in going to spend money when I have perfectly good working cards LOL.
So overkill all the way.
It's not required at all, nor should 850/1200 be considered an overclock. Although it's becoming tiresome, I'll try to explain again.
The 5970 was downclocked to 5850 speeds, ONLY to stay under the 300w max for PCI-E 1.1 - PCI-E 2.0 is capable of an additional 75w, total 375w. They wanted people who only have 1.1 to be able to run the card, and those people need a downclock. Anyone with 2.0 can clock it to normal 5870 spec with zero issues.
Also, I overclock/overvolt for no real reason other than because I can. Frankly these are such overkill for anything out there, you will not notice any difference in performance whatsoever - only in benching. I mean, 5500 fps or 4900? lmao....
Edit: But OP is free to do as he pleases, just hate for it to be based on false/old/regurgitated info. And I'm surprised nobody is saying to dump the R2E and get an SSD.
2x 5870 will be faster than a 5970, but you lose a PCIe slow on the 2x 5870s if you ever plan to upgrade. Also, you can always just overclock the 5970 to the 5870 specs.
Although both my face and palm are beginning to ache, I'm going ot have to
Why do you have lots of GTX 285 cards? Did you rob Nvidia HQ?
If you're just going to start losing them... you could leave some with me for a while
Common sense?
Originally Posted by liberalelephant View Post
Common sense?
Compelling argument, I concede.
/sigh
1 - 20 of 46 Posts
