61 - 75 of 75 Posts
Discussion Starter · #61 ·
So i was checking GTAV and VRAM usage. So in game settings were maxed except AA stuff. I found @ 4k it was about 3gb used in AB and said 3173MB in GTAV settings window. Now at 6400x3600 same setitngs i was hitting 3.9GB in AB and GTAV settings menu showed 4.8GB. So i had to use the "ignore suggested limits" option. Wierd how none of it really matches up. These were recorded on a single 290x 4GB to get proper memory size. CF was disabled. EDIT: left advanced settings default
6400x3600 settings used(4k also)
3.9GB used in AB if you dont want to view full size.
4k shots same settings
2.9GB used in [email protected] if you don't want to view full size.
Discussion Starter · #62 ·
I guess with the new drivers out 15.5 i will get Witcher 3 now. If it works in 2x2 eyefinity quad CFX and Quad VSR does that mean the driver sucks?
EDIT:
Call of Juarez: Gunslinger
ran like 60fps-90fps not exactly graphical but still looks decent.
Discussion Starter · #63 ·
Spoke too soon, CF is playable with AFR, however any profile setting used and i get flickering. So for the sake of sharing i ran single gpu to get some screenshots. I guess it doesn't look to bad once your out of the starting area. There are some fairly obvious textures they skimped badly on, but most of the time your easily distracted elsewhere.
6400x3600 everything maxed except Hairworks off, and No AA
So... How many Fury are going to drive this display now?
Hacktun3d
Any real reason to use that bios? Using the modded 300 driver and matched clocks my 290's are getting the same results (based on what little benchmarks we have). Just wondering if I should rock the bios' instead/ as well
Discussion Starter · #69 ·
I am not sure, i wanted to see how it does on a single gpu and then if crossfire does much. In the long run i was thinking tri-fire fury. I just don't know though until i see performance numbers and prices.
Also keep in mind, fury will have 4k VSR, so i could possibly run 4kx4 lol. (don't expect it to work but i am damn sure gonna try it for funsies) I also may look into getting or setting up 4k eyefinity again.
However i currently have 6400x3600 23MP vs 4k eyefinity being 6480x3840 24.9MP - so it may not be worth it right now.(aside from better field of view and immersiveness with size) I am still blown away how badass this looks in games. i am gonna nab another camera soon just havent had much time to look for one.
I don't have solid numbers or proof per se but i score better in Firestrike and crossfire seems to be running better. It may just be drivers i dunno. I will probably use my pcie disable jumpers soon and bench clock vs clock on 290x vs 290x w 390x bios.
Hacktun3d
Thanks! I decided to just go ahead and give it a whirl.. makes it easier to install the "300" driver instead of waiting for the hacked version LOL
Discussion Starter · #72 ·
Alright so, doing a little testing 2x2 eyefinity @ 4k per input instead of 3k. total resolution 7860x4320. I was curious about vram limits and only tested so far Crysis 3. to do this i had to use Toastyx's AMD pixel patch to unlock [email protected] per input. Unfortunately to run this normally, it would be limited to 30hz as per my 2 HDMI ports are 1.4 as well as HDMI on the 290x. I was just curious and as such this is just a demonstration.
Lets compare Visual quality raw resolution against both itself and what settings would look like maxed on the low end.
7680x4320 Crysis 3 very high textures, very low preset, no AA
vs
1080p MAX settings, Very high preset, Very high textures, 8xMSAA
Also for apples to apples 1080p, very high textures, low preset, no aa
View the originals if you can, the results also will vary depending on your desktop resolution but should still be noticeable between the two.
EDIT: P.S. i forgot to mention vram wise, at low/medium i did not appear to be hitting the vram wall. however above that i started to hit the wall as noticeable by just playing and massive stuttering FPS dips. I wanted to see if this would be an issue for FuryX and it very could be IF i had a fracking card to test with. Unfortunately they seems to be like the Lochness Monster they aren't anywhere to be found.
Forgot to post the proof shot:
subbed and repped
Discussion Starter · #75 ·
Now that i have my own pad, i'm researching about going projector route. If i do, then i will still use my 44k but as a backup. I would love eyefinity on a whole wall, no doubt. I just need to see how feasible things like input lag/clarity etc will be. I am only considering this now because it's almost impossible to get Fury gpus right now and maybe it would be a better investment instead and i could use my little 290x quadfire a while longer.
I really wanted a fury even if just for testing 4k VSR over HDMI to simulate 4k 60hz over hdmi 1.4. I was really curious about how this monitor and scaling would be. I still am looking for a decent camera setup to record gameplay at high res as well.
I'll be back!
61 - 75 of 75 Posts
